Page setup
Command
Path
Shortcut
Page Setup
File
Ctrl+Alt+P
The Page Setup dialog box settings determine the number of sheets of paper (pages) required to print the entire drawing on the selected printer. It is also used to specify whether to display the gray box representing the print area for design layers, and whether to display page breaks in the drawing file.
To change the page setup settings:
Select the command. The Page Setup dialog box opens.
Parameter
Description
Pages
Horizontal
Specify the number of pages in the horizontal direction
Vertical
Specify the number of pages in the vertical direction
Show page boundary
Displays a gray border around the perimeter of the print area for design layers (this setting is selected by default); alternatively, press Alt+B (Windows) or Command+B (Mac) to toggle selection in this field.
Sheet layers always display the page boundary.
Show page breaks
Indicates how the drawing is divided over each printable page; for design layers, the page boundary must be displayed in order to see the page breaks (this setting is selected by default)
Show watermarks
If the file is created in an educational version of Vectorworks products, it includes a watermark. This option is selected by default and indicates whether to display watermarks on screen, at the top and bottom of every page boundary; the page boundary must be displayed in order to see the watermarks.
The title bar clearly indicates watermarked files. A watermarked file always prints the watermark, regardless of the display option set here.
Printable Area
Choose size unavailable in printer setup
If the desired paper size is not available in the Printer Setup dialog box (see Printer setup), select this option, and then select the desired paper Size from the list; this is useful when sending files to a print bureau that has different paper sizes available
Size/Width/Height
To manually specify the paper size, select the appropriate drawing units (inch or millimeter) and enter the paper Width and Height
Printer Setup
Accesses the Printer Setup dialog box for specifying the printer, paper size, drawing scale, and orientation; see Printer setup
